Nest - Variable Speed Compatibility Question
Old 01-15-20, 07:14 PM
C
I was told by my HVAC maintenance personnel that using the Nest thermostat wonít allow the variable speed fans to function properly causing inefficiency in the system. I have the same setup as shown in CB242ís first set of pictures for his downstairs configuration using the TCONT803AS32DAA thermostat. I donít want to purchase a Nest thermostat for this system and it causes issues. Can someone help with this?
Old 01-16-20, 06:27 PM
Received 4,046 Upvotes on 3,630 Posts
Welcome to the forums.
Your post was moved to its own thread due to the length of the one you posted on.
THIS is a link to the thread you originally posted in.
