Picking the right thermostat.
Received 0 Votes
Morning, I just moved into a new house and am looking at getting a smart thermostat. I grew up in a house with just oil heating and AC's in the rooms so a swap was easy, but now I have a CA system as well as oil. I just want to make sure I buy the right thermostat and know if I need to run a C cable. Here's what the guts of the older one look like.
Welcome to the forums.
You have two systems controlled by that thermostat. Two distinct cables.
Cable 1............... The heat is on red(Rh) and white(W).
Cable 2............... The A/C is on red(Rc), green(G) and white(W).
You absolutely need a C connection and it comes from the A/C air handler.
Check and see if there are any cut off wires in the A/C cable.
You have two options.....
1) run a new cable down to the stat. (recommended)
2) you can lose control of the blower at the thermostat and use the fan wire as the C wire.
With this method.... there is no more "FAN ON" mode.
Received 0 Votes
Sounds good, sorry if the info I was giving wasn't nearly helpful enough. By oil heating I mean that I have furnace and baseboard heating. And the cooling is a Goodman A24-00. You wouldn't happen to have a link to a wiring diagram so I can put that C wire in properly?
C is the big light gray wire under your thumb in the picture that you posted.
The AC condenser connects to stat Y and air handler C so you will end up with 2 wires connected to the air handler C.
So have we helped you make a decision ?
Any more questions ?
The Ecobee 3 is a good choice...... Honeywell T6 is another.
In your picture in post 3...... that white/gray wire in your thumb is C. You can connect right there.
In your picture..... there is a three wire cable. This cable goes to the stat. If it's still being used..... R (red) goes to orange color. G (green) goes to yellow and white goes to red of the A/C condenser.
How did you get C to the stat ? One wire.... new cable... ?
Received 0 Votes
I used the white wire that's connected to the thick grey cable, because from what I understood was that since it was connected to the grey cable, it would act as a C. But obviously that didn't work. So can I just add a third cable to the grey cable and white wire twist and use that as my C? As I was going over the ecobee instructions it seems that the main issue I'm coming up with is that I have a dual transformer system. I just can't figure out where the C wire is supposed to start at the A/C.
Ok..... let's just take a step back. From what you've said and what I see in your pictures you have three wires between the air handler and the thermostat. You need a fourth wire.
How are you going to get a 4th wire to the thermostat ?
Received 0 Votes
I was planning on snaking it from the hole in the wall to wherever the C needs to start from. I know easier said than done, but that's the plan. I've run ethernet cable through the house so I know it's a pain but doable.
Ok.... so that wire you are going to run connects to the C of the thermostat and the gray wire at the air handler.
