Nest 2nd Gen add C and * wire
Old 03-19-20, 02:29 PM
F
I have a 4 wire thermostat cable and despite trying my best, I couldnt get it replaced with a 7 wire cable that I bought (cable is stuck somewhere). I see some videos where it explains how to use the G wire as C wire. My question is how do i now use the * wire for Aprilaire 600M humidifier. Would add a wire work? Someone posted that i need 2 add a wire(One for C and one for *). Would appreciate your help. currently i have a honewell wiresaver but planning to remove it.
Top Answer
03-21-20, 12:31 PM
PJmax
PJmax is offline
Received 4,052 Upvotes on 3,635 Posts
Ok..... I modified the diagram for that model based on your installation.
The purple jumper between G and Y can be any type of wire.... even bare.
The H in the circle is the humidifier solenoid.
Old 03-19-20, 04:17 PM
A
Received 92 Upvotes on 84 Posts
Not cheap as you would need something like a Fast-Stat to add 2 wires. Model 3000 or 5000 - https://www.fast-stat.com/
Old 03-19-20, 05:54 PM
F
Can i not use the add a wire module (venstar)and wire the green as * and connect it directly to one of the solenoids?
Old 03-19-20, 06:23 PM
A
To do it right you would have a G wire at Nest. Since you don't have it now maybe you wouldn't miss it.
So yes, you could use the Venstar. You would first remove the Honeywell module and put a jumper wire on the furnace terminals between Y and G. Then install the Venstar Add-A-Wire with one end of its green going to the humidifier and the diode at Nest going to *. Other connections as shown in the installation instructions https://files.venstar.com/accessorie...ManualRev2.pdf .
faisal zaman voted this post useful.
Old 03-19-20, 07:50 PM
I had problems with the conversion modules and the nest thermostats.
Now I only install wifi stats (especially the nests) with the correct cable.
Adding a humidifier on top of this will not help the situation.
Old 03-20-20, 10:29 AM
F
Thanks a lot. One more question. Can I get away without using the relay for humidifier?
Old 03-20-20, 10:32 AM
An Aprilaire 600 requires 24vAC on the solenoid wires to operate.
It doesn't require a relay in this situation.
Old 03-20-20, 11:02 PM
F
Mounted it to the vent. Waiting for venstar to arrive(Amazon). Question on wiring:
I read that i don't need to use the provided transformer. So I connect one yellow wire from the solenoid to C on furnace and the other one to Green wire in Venstar (* wire)?
For testing, if I connect the other wire to W, it should keep running while the heat is on right?
Old 03-21-20, 09:21 AM
Venstar ? What exact model are you using ?
One solenoid wire to C is correct.
The other solenoid wire needs to be connected to or controlled by the * terminal on the nest.
Old 03-21-20, 11:45 AM
F
Venstar ACC0410 Add-A-Wire Accessory for All 24 VAC Thermostats (4 to 5 Wires)
so I was planning to join y and * wire to the y diode and then connect the corresponding * to solenoid with a wire twister
Old 03-21-20, 12:31 PM
Attachment 113538
Astuff, faisal zaman voted this post useful.
Old 03-21-20, 02:51 PM
F
This is exactly what i planned. Thanks a lot..
