Honeywell RTH6360D1002 installation
Old 03-25-20, 11:01 AM
A
I installed the new Honeywell thermostat and the heating is not turning on. I have a Bryant Plus80 furnace #CK5BXW036021AAAA.
I have 4 wires as shown in the picture. Old thermostat had a jumper wire from RC to RH.
Did I install this correct or can you assist in why thr heating isn't turning on?
Thank you
Old 03-25-20, 11:15 AM
coolmen's Avatar
red wire {24v) powers thermostat RH for a heating only setup. The jumper allows power to RC for cooling as well. Most often jumper is used for a normal single furnace with a ac coil on top to heat and cool the house.
Jumper is removed if using a furnace and also a airhandler maybe in attic with its own transformer.
Old 03-25-20, 11:17 AM
A
old thermostat:
New Honeywell
Old 03-25-20, 11:21 AM
coolmen's Avatar
put on W not w2 the shaded areas
Old 03-25-20, 11:28 AM
A
I had originally put it in the shaded W, but it wasn't working, so I switched it to the W2. Would there be any other reason heating isn't turning on if it were connected correctly to W?
*edited* changed the wire back to W and it's working now. Thank you!!
Old 03-25-20, 04:14 PM
Received 733 Votes on 688 Posts
Welcome to the forums.
Quite possibly the wire wasn't pushed all the way into the terminal to make connection.
Those new style connectors are miserable.
