4h2c heat pump with electric backup and oil boiler
Old 04-10-20, 06:10 PM
P
PJmax Me again. This time we are installing a Bosch 2.0 system 3 ton AH and HP with a 15kw heat strip. My puzzle is, I would like to use a 4h/2c stat to take full advantage of the new unit, but then after a certain outdoor temp say 40 degrees I would like to automatically switch from the HP/backup to strictly oil heat. What is the easiest way to do this?
I also want to utilize the DeHumidification setting of the HP/AH.
Can I use a Tstat with a w3 terminal to energize a dpdt relay to switch R from the HP to the boiler and at the same time break Y to open so the compressor can't run.
Or should I switch W1 to boiler as well instead of worrying about Y1
Or would that still energize W1 and W2 to call for the Heat strip?
Aquastat??
Thanks in advance, Joe
Old 04-11-20, 02:53 PM
Received 1,344 Votes on 1,242 Posts
A little confusing.
Question..... why not use the oil in place of the electric reheats ?
It's got to be less costly or are you getting a steal on electric rates ?
Old 04-11-20, 04:45 PM
P
Yes my electric rates are good up to a point which why at the lower temps I want to auto switch to the oil.
Is switching the R and W1 on the right track?
I guess I forgot to mention I was trying to do it all with 1 Thermostat
Old 04-11-20, 04:56 PM
Basically you want to make your own fossil fuel kit.
It's not as easy as 1-2-3.
You need to consider things like hysteresis. For example..... if the temperature gets to 40° and stays there. What will the system do..... keep toggling from electric to oil ? You need a way to incorporate a deadband.... a set of points where the system stays in one mode.
Old 04-11-20, 04:59 PM
P
Yes , point well taken.
Maybe 2 stats is just easier with a manual switch over.
Just ugly,clunky, and not automatic.
Have been revisiting this for several days, before hitting you up.
Still curious what you might do?
With a W3 stat I believe I can set a deadband point, Have 2 c check
