Thermostat for PTAC? Applied Comfort scwc15k00q7a42
Old 05-15-20, 12:57 PM
W
I have an Applied Comfort scwc15k00q7a42 PTAC in my apartment. The unit has 1/2 (low/high) heating and 1/2 cooling settings, where the PTAC itself supplies AC, and in the cold parts of the year, heat is driven by blowing air thru a hot water radiator that is regulated by a zone valve connected to the PTAC.
My primary issue today is that the PTAC's built in thermostat isn't working properly -- it works, but doesn't cool lower than ~mid-70s. Almost seems like a calibration issue, as if I hold the "sensor," it starts cooling again from the warmth of my hand. Any general suggestions around what could be causing that?
Separately, if I'm going to try to fix this, it occurred to me that it might be nice to try to wire in a smart thermostat ala Ecobee or Nest. Is this even an option? Wiring diagram and what I can see in the AC are 3 wires coming in/out of the thermostat... red, white, black.
Here's the link to the AC & parts list: SCWC15K00Q7A42 Service Parts | Applied Comfort Products
Here's their PDF of the wiring diagram: http://www.ptacs.com/static/products/wiring/802599.pdf
Any help or advice would be appreciated. Let me know if I missed any crucial info. Thank you!
Old 05-15-20, 09:42 PM
Received 1,505 Votes on 1,393 Posts
Welcome to the forums.
In order to use a wifi stat.... you would replace that current thermostat with a high current relay that could be controlled by a low voltage thermostat. It could control temperature but not turn the unit on or off or change blower speed. That would require extensive work and not be easily done via online help.
That thermostat is a basic remote sense bulb type. There may be a screw somewhere on it to recalibrate it. They aren't really designed to be recalibrated. If you find the screw..... you must turn it a little at a time and keep track of exactly which way and how much you changed it.
Old 05-18-20, 07:20 AM
W
Thanks PJmax. Sounds like a definite "no" on the smart thermostat.
I didn't notice any screws on the existing, but will take a look the next opportunity I have. Also trying to locate a replacement to potentially just swap in a new part.
Old 05-18-20, 10:07 AM
That is an 800617 thermostat.
Not too many choices in locating it.
It's possible with the temperature spread known to locate a universal one.
There may be an original mfg part number on the old one.
Williams HVAC
Applied Comfort
Old 06-01-20, 05:32 PM
W
Just to semi-close the loop in case this is ever helpful for someone else... I had no luck finding the thermostat myself -- emailed a couple random Canadian distributors I found with Google (including Williams, linked above) and got no response. I ended up emailing Applied Comfort at sales@ptacs.com to ask how to find the part. They put me in touch with a distributor in NY -- http://www.daikinapplied.com/. Daikin quoted me $75+tax+shipping for a replacement. Still waiting for info to make payment but I am likely stuck going down that route.
Thanks for the help, PJMax.
Edit: Forgot to mention -- I *did* look at the existing thermostat for a part number to help my search, but this is a refurb unit and the the way the existing was installed makes me suspect that the guy that sold it to my landlord replaced it himself and did so with the wrong part. I'm hoping that's the reason it isn't working properly. That seller seems to be out of business, so is no help. I didn't want to search for a new, wrong part. Hence paying up for the OEM answer.
Old 06-01-20, 07:05 PM
Good detective work. Let us know how everything goes.
