Powering An Uninstalled Thermostat
Can a wireless thermostat be powered without connecting to the system?
I have a Lux GEO thermostat that seems to not be reading the air temperature incorrectly. I would like to put the previous wireless thermostat back in place to compare but the Lux, obviously, would need power to read.
Thanks
Edit to add: There is no C wire in use. The unit is battery powered but does have a usb power input
Thanks
These are wifi thermostats..... not wireless.
The Lux GEO is a universal system compatible thermostat that offers 3-power options: 2 AA Lithium batteries, a micro-USB, or the C-wire.
goofyfish voted this post useful.
Thanks, both of you. So there should not be any danger of damaging the thermostat while powered up and not connected to anything (I guess this a clearer question than what I wrote)?
Keep in mind you cannot hold the thermostat to check it.
Your body heat will cause it to show warmer.
