Honeywell thermostat install
Received 0 Votes
honeywell rth6580wf thermostat install, furnace only has heat and runs only 2 wires, i need help with install and how to wire new thermostat. i can upload pics if needed thanks for any and all input. the pic is of old thermo wires. the furnace has 2 wires as well a red wire attached to the "R" and a white wire attached to the "W1" any suggestions or will i need all new wiring?
The rth6580wf requires a 3rd wire for C/Common used to power it up. You either need a thermostat that uses batteries, run an additional wire to your hvac system, or use a device such as a common maker.
