Upgraded from Honeywell to Honeywell thermostat
Old 10-16-20, 03:07 PM
F
So the up button didn't want to work unless you really smushed it and wiggled it around. So I bought a new one. I hooked it up about 3 months ago but now the heat doesn't blow any heat, just cold.
Here is the old one.
So I put up the new one wiring it like the manual says for a 1h/1c heatpump.
It worked great all summer for the a/c.
Here is a link to the manual. https://digitalassets.resideo.com/da...3-00181EFS.pdf
Old 10-16-20, 03:11 PM
F
Oh here is how I have it wired to new thermostat.
Old 10-16-20, 03:50 PM
Received 1,110 Votes on 1,030 Posts
Welcome to the forums.
Your wiring is ok.
Most of the default program settings are ok.
You must change the following three for your system.
200 = 2 - heat pump
205 = 7 - Air to air heat pump
218 = 1 - B (O/B in heat)
Old 10-16-20, 04:22 PM
F
Thank you for your reply. I was sure I already had that set correctly, but I went and wrote down all my settings to be sure.
120-2
125-0
200-2
205-7
218-1
220-1
221-1
300-0
340-10
350-0
365-3
375-9
387-2
425-0
430-60
431-80
435-0
702-1
711-6
1400-0
1410-12
1415-1
1420-0
Old 10-16-20, 04:48 PM
F
Don't know if this helps but the Heat pump is a Rheem.
Old 10-16-20, 05:26 PM
Your settings look ok.
The O/B supplies power to the reversing valve. The majority of the companies use O for cooling. That means the valve is powered to cool. Rheem and Ruud are two companies that use B for heating. That means the valve is powered to heat. Just the opposite of everyone else.
If I was checking your system.... in heating mode.... I'd go out to the condenser and check from the blue wire to the C wire. You should see 24vAC there. If you do see it there.... it could be a defective reversing valve coil (open) or a problem with the defrost control board inside the condenser.
Do you get heat in emergency mode ?
That would shut down the compressor and use the electric reheats.
