In ProcessAdSlots.php line 39: Trying to access array offset on value of type null
“C” wire boiler side termination location (L7224C)
Old 11-20-20, 03:03 PM
Hi, in a Honeywell control box, could someone point to the recommended “C” wire spot? I’m installing a new thermostat and have an obvious 2 wire system. Ty in advance.
Old 11-20-20, 04:12 PM
A
Received 46 Votes on 41 Posts
They don't advertise this but looks like the 2 terminal is C. The shared 3 and T terminal is R while the end T is W.
Old 11-20-20, 05:37 PM
Ty
Ty it makes sense. Should be ok as long as 24v @ #2 right? It’s just for power
Old 11-20-20, 06:20 PM
P
Received 2 Votes on 2 Posts
the "R" to the thermostat should make 24V with the common, "C". That will power your stat. Unfortunately, they typically don't advertise a 24V "C" terminal on the aquastat because they aren't designed to power other equipment like that. the easiest way to find the common on the aqua stat is by looking at the circuit board tracing on the back side (not so easy to view, though). specifically, the traces coming off on the built-in transformer.
One concern is the rating for the transformer built into that aquastat. I am not sure what the VA (the load it can handle to power equipment) typically is on an aquastat, but adding any additional devices that need power (ie your new thermostat) that it wasn't designed to handle, you always risks overloading and killing the transformer. which kills the aquastat ($200+). Your alternative option is to add an isolation relay and an independent transformer. Not hard to do but it requires a bit of thought and some electrical no how.
Old 11-20-20, 06:21 PM
Checked voltages
Lug: 1-20.4v. 2. 30.4v. 3. 8.9v 4. 0v
Old 11-20-20, 06:35 PM
Aqua stat schematic
This is my model diagram below. It shows a 24v thermostat top right. It shows “T T”. In the actual pic I posted above, to me it shows lug 3/4 as T T. But, lug 1. Has 20v, lug 2 30v, lug 3. 8v, lug 4 0v.
Old 11-21-20, 06:23 PM
Received 1,180 Votes on 1,093 Posts
Use the info in the following thread for help...........
wiring-new-honeywell-thermostat-honeywell-aquastat-controller.
