Nest thermostat controlling 24 V valves for baseboard water heat
Old 03-29-21, 08:22 AM
H
I am installing Nest thermostats to control 24 V valves (normally closed) for baseboard water heat. These will keep those rooms cool when they are not needed.
I know I should connect the 24 V transformer to the Rc and C terminals. How to I power the 24 V valves?
Old 03-30-21, 04:39 AM
C
Received 4 Votes on 4 Posts
How are you powering the valves currently?
Old 03-30-21, 08:34 AM
Received 1,480 Votes on 1,368 Posts
Welcome to the the forums,
The nest doesn't supply 24v to the valves.
It switches it from a transformer you should have already in place.
A few pictures of your wiring around the valves would be helpful..... how-to-insert-pictures.
