smart thermostat on two wire
Old 04-12-21, 06:09 PM
I have baseboard water heat with a gas fired boiler. two zones. I'm trying to wire up a Honeywell RTH6580WF smart thermostat. it needs a c wire. I only have two wires. I do have third wire at each thermostat. I don't know where to hook it up. here are some pics.
Old 04-13-21, 07:09 PM
Geochurchi's Avatar
Received 91 Votes on 86 Posts
Hi, post some pics of where that thermostat cable terminates.
Geo 🇺🇸
Old 04-14-21, 08:09 PM
here is where the thermostat wires connect to the wires off that thingamajig.
Old 04-14-21, 08:15 PM
the thingamajig is what is in the second pic. I think that is where the power comes from.
Old 04-16-21, 09:34 AM
Received 1,514 Votes on 1,400 Posts
I can see you have three wires to the stat. Green is currently not used and can be used for C.
I've labeled your picture.
I don't know which valve is for which zone but the TR connection is also the C connection.
Your stats are currently set up for TH/TR = red = R and TH = white = W.
Now TR = green = C.
Old 04-17-21, 05:21 PM
thank you very much. I have two zones so I bought two smart thermostats. do I only need one? do both zones get connected to the same tr screw? or do I connect one green wire to left zone valve and one green wire to the right zone valve?
Old 04-17-21, 08:57 PM
You need two thermostats..... one for each zone.... unless you want one stat to operate both zones.
Each wifi stat would get a C connection.
Old 04-18-21, 05:37 PM
I dont want to seem dense. the red wires remain attached and I just add the green wire to each zone on the third screw. correct? thank you for help.
Old 04-19-21, 04:01 PM
The red and white wires are in the correct location on the valves.
You will just connect the green wires.
