Need help with nest power connector
  #41
Old 04-12-22, 07:11 PM
Received 2,980 Votes on 2,688 Posts
Yes....you'll need to strip back the thermostat jacket to find the green wire.
You can connect all three together and run one wire to any C terminal.
  #42
Old 04-12-22, 07:36 PM
D
Received 1 Vote on 1 Post
Thank you so much for all your help with this!! All 3 stats are now functioning correctly.
  #43
Old 04-12-22, 08:43 PM
Your welcome.
Thanks for the pictures too as they helped me get that Taco unit identified correctly.
  #44
Old 04-13-22, 03:55 PM
P
Received 26 Votes on 22 Posts
yup, mimic the wiring for zone 1 on zones 2 and 3. should work for you.
BUT...
your thermostat wires come in the top of the panel. Your zone valve wires come in the bottom of the pannel. DID YOU MOVE A GREEN ZONE VALVE WIRE? I see in the latest photos the zone valve green wire is in terminal 1 along with the red wire at the bottom of the panel. Did you do that? That is incorrect and your zone valve won't work properly. (when we talk about "green wire" above, we meant from the thermostat wire bundle, not the zone valve wire bundle)
and, in case you are wondering, the thermostat can work even if the zone valve is wired up wrong.
  #45
Old 04-13-22, 05:18 PM
D
I moved the zone valve wires back to 1,2,3 last night and just moved the green Stat wire to terminal 1 of the zone valve wires on each zone.
pbct2019 voted this post useful.
