Thermostat has no C terminal
Old 07-12-22, 10:02 AM
L
My daughters house is a gas heat with electric A/C.
I want to upgrade my daughters thermostat to a wifi programmable one.
The old thermostat does not have a C terminal and only uses the following:
Blue wire to B term
Green wire to G term
Yellow wire to Y term
White wire to W term
Red wire to R term and jumper to RC term.
I went to honeywell's site and used some app on there to help pick a new thermostat. After telling it which wires I had and what terminals were in use, it said it couldn't help me and to contact a professional.
Any ideas on a programmable thermostat that would work? Wifi is a preferred option, but not a requirement.
Old 07-12-22, 10:24 AM
Received 2,949 Votes on 2,662 Posts
Welcome to the forums.
Assuming you have a Trane or Trane branded furnace.....
R --------> red -----------> R
W -------> white --------> W
Y --------> yellow -------> Y
G -------> green --------> G
B -------> blue ----------> B
Any thermostat in the Honeywell line will work for you.
Correction; B is not a C. Terminal. B is stating that this is a heatpump system.
Old 07-18-22, 08:47 AM
L
Thanks
Thanks PJmax,
I don't know the brand of the furnace as all the labels are unreadable.
What about the jumper between R and RC?
Thanks
Old 07-18-22, 08:51 AM
Most thermostats come with a jumper..... just leave it.
Old 07-19-22, 04:20 PM
Geochurchi's Avatar
Received 154 Votes on 140 Posts
Hi, to be sure that you have a Common, test between R &C with a multimeter, you should get 24VAC
Geo🇺🇸
Old 07-20-22, 02:35 PM
A
Received 79 Votes on 71 Posts
On that thermostat B is a B. You can see on the backplate that the "not used" pin is C.
Best to get a picture of the wiring at the furnace end. The blue wire might not even be hooked up to anything.
Old 07-20-22, 04:22 PM
Good catch Astuff.
There is no C wire present there.
B suggests you have a Rheem or Ruud heat pump.
You MUST confirm exactly what equipment you have.
Old 08-04-22, 11:30 AM
L
I want to thank everyone for their input. So I was finally able to get back over to her house and look at the furnace.
Looking at the terminal block in the furnace, the wires are as follows:
R - R
Y - Y
G - G
W - W
B is not connected to any terminal in the furnace.
Can I connect the blue wire to the C terminal in the furnace and to a C terminal in a new thermostat?
Old 08-04-22, 12:37 PM
Yes... you can connect the blue wire like that.
Old 08-05-22, 07:57 AM
L
Thanks for all the assistance.
Old 08-23-22, 12:49 PM
L
Thanks to everyone. Finally got back over to her house. Got the new thermostat wired in and working great.
Old 08-23-22, 04:12 PM
Good job. .. . Thanks for letting us know all went well.
