Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Thermostatic Controls
Reload this Page >
Installing an WIFI thermostat and have 2 questions with the wires...
Old 08-13-22, 12:13 PM
A
Received 2 Votes on 2 Posts
1) For our existing thermostat, we have a wire going to Y2 and not to Y. I read that Y is one that is required for this WIFI thermostat (the shaded ones in the screenshot are supposedly required). So should I place the Y2 wire into Y or Y2 on the new one?
2) Sort of the same with our R wire. It's currently going to R2 but R2 is blocked off with a blue tab (again, see screenshot). So what about this one? Can I safely go to R?
Old 08-13-22, 01:48 PM
Received 2,957 Votes on 2,668 Posts
There is no R2.... do you mean Rc ?
If you only have one R wire.... you set the slide switch to one wire and use the only spot available.
I can't answer the Y question without a picture or the old wiring or the model number of the old stat.
Old 08-13-22, 02:09 PM
Geochurchi's Avatar
Received 154 Votes on 140 Posts
Hi, post some pics of the furnace control board , also type of equipment your dealing with.
Geo🇺🇸
Old 08-13-22, 06:53 PM
Houston204's Avatar
Received 38 Votes on 34 Posts
1. Connect to Y on the new stat.
2. Connect to R on the new stat.
