Johnson Controls FCP-NA-701
Old 05-11-24, 02:51 PM
R
Can someone point me to videos on a FCP-NA-701 thermostat please. I just moved in to a place with this control and the fan coil is running but the thermostat is completely blank. I'm trying to figure out how to remove it from the back plate to check the wiring. Thanks
Old 05-11-24, 05:17 PM
Received 4,059 Upvotes on 3,642 Posts
The thermostat runs on 24vac. I'd check for the 24v at the FCU first.
I don't believe there are any videos out on that stat.
Just a manual.... FCP-NA-701 - pdf
Old 05-12-24, 05:01 AM
R
what or where can i find the 24vac on the FCU?
Also, i found 3 diff manuals on this FCU. All of them contain a lot of settings/configuration info but not the basics. The manual you provided below is what the unit came with.
For example:
1. How do i determine if it is connected to a 2pipe or 4pipe
2. whether the thermostat is a programmable or non-programmable
3. The blower seems to be running constantly. It doesn't appear to have an OFF setting like most tstats out there
Old 05-18-24, 04:05 PM
R
Can someone tell me if the fan coil unit's blower is supposed to be running constantly even though the thermostat is already set to OFF. If it's not supposed to do that, please let me know what to change in the settings to fix that. This is related to the FCP-NA-701 thermostat. thanks
