Toilet Leak - on connection into tank
Old 01-22-04, 09:52 AM
brinkdog
I noticed a small leak in my toilet. It only leaks when the water is turned on. Initially, I thought that the rubber ball ck gasket inside the tank had worn out but I replaced it and there is still a leak. What parts between the wall and the tank might be causing the leak? Thanks in advance for the help.
Old 01-22-04, 10:02 AM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
Cool
Is the nut (holding the supply line to the fill valve) at the bottom of the tank leaking?
If that's it, wrap 2-3 flat wraps of teflon tape counter-clockwise (because it's upside down) on the threads, and then tighten the nut onto the fill valve.
Good Luck!
Old 01-22-04, 10:24 AM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
Install a new supply line, use a braided flex supply, if you have not replaced the supply line yet.
Old 01-26-04, 10:40 AM
brinkdog
The old supply line was affixed permanently to the shut off valve so I ended up replacing the shut off valve, supply line and ballcok. This seems to have fixed things except now I have a small drip in the shut off valve on the connection from the pipe to the valve (compressor connection). Maybe I should just tighten it more although I think the instructions warned against over tightening.
Old 01-26-04, 12:35 PM
Shut water back off, back off nut and remove valve.
Then take a small amount of teflon thread sealant and apply a minimal amount on the front side of brass ferrule on copper pipe.
This is the point of contact where water can leak; doping the threads on compression valves is not where the source of water is.
