Best solution for sweating toilet
Old 03-03-04, 02:32 AM
maryannkacz
Question Best solution for sweating toilet
Have a serious condensation problem on toilet tank and bowl. Keep recaulking around toilet, and caulk doesn't even get a chance to dry. House is on a slab, which I think may contribute to problem. We are buying a new toilet. I have heard pressure assist ones can prevent condensation. Plumber also said a mixing valve on water line will help. Already tried other things, a drip catcher, fuzzy tank liner. Will the new toilet solve this problem, or should I just get a regular toilet and put the mixing valve on? I know the pressure assist toilets cost more, but it is worth it if it will solve the problem. Anyone had success with these as far as condensation goes?
Old 03-03-04, 05:39 AM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
Too much humidity, try a dehumidifier in the bathroom.
A pressure assist toilet will keep the sweat down at the tank, but if the bowl has a sweat problem also there is nothing to solve that issue.
Old 03-03-04, 01:46 PM
