tub diverter
Old 04-12-04, 05:21 PM
JBAKAITIS
Question Shower Diverter
My faucet in the tub still runs water when I pull up the diverter. There is plenty of water pressure in the shower but still water comes out of the tub faucet. I changed the tub faucet to no avail. Please help quick. I'm trying to sell my house. Thanks so much for your time. Janet Bakaitis
Old 04-12-04, 05:42 PM
L
Received 1 Upvote on 1 Post
Since your diverter seems to be located on the tub spout, changing the spout should fix the problem.
Old 04-13-04, 09:00 PM
JBAKAITIS
Exclamation tub diverter
Thank you lefty for your reply but I did change the faucet on the tub diverter and I still get water out of the faucet and the shower. Please help. Water runs out of the tub faucet. The diverter is on the faucet spout I changed the faucet but still get water. What now?? Thanks Janet
Old 04-14-04, 05:47 AM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Upvotes on 4 Posts
Lightbulb My 2 Cents
Hello: Janet
The problem may not exist with the faucet. Since you changed it or replaced it, take the focus off the faucet and try this.
Remove the shower head. Turn on the water and lift the diverter valve as normally done. Note any difference. Chances may be the water back pressure caused by the shower head, new or not.
Shower head may be causing to much resistence to the water flow. Thus the faucet diverter is dumping the excess out of the faucets diverter valve.
Just a guess here which may or may not resolve the problem. Intent is to take the focus off where the problem is thought to be and place the attention on another possible area....
Regards & Good Luck
Web Site Host & Forums Monitor
Old 04-14-04, 07:15 PM
JBAKAITIS
Wink shower diverter
Thank you thank you thank you it was the shower head cause when I took it off and switched the diverter no water ran out. Can't thank you enough. I'm only good for medical advice but if you need some email me. Janet
