Garbage Disposal won't drain
ISE Garbage Disposal won't drain
Pro 333 model/ser 55492399
The water won't drain out ; I put my arm down and all parts turn properly......other sink drain works fine
we do not have children nor did we put anything in it we shouldn't have....
It is 2 yrs old, I don't have a manual; tried internet search w/no luck
Ran the diswasher........oops, more water sink now half full........
fast advice appreciated
BTW, I have the "tool" but don't know what to do with it;
did try reset button 3 times w/no luck
Received 5 Upvotes
Hello: bhk
There is a drain line out of the disposal going into the drain pipe. Chances are that line out of the disposal is clogged. It will have to be removed. Have a pan or small bucket under the line when it is removed. Water will pour out.
The line it feeds or ties into is either clogged, the part removed is clogged or the line to the sewage line is plugged. Make have to snake the line clear.
The tool you mention is likely that which is used to clear or loosen stuck disposal blades. Not needed if the blades can be rotated by hand.
Question moved out of electrical appliances forum to this forum topic.
Professional plumbers may be able to help further.
If you need further assistance, use the reply button to add any additional information or ask additional questions. Doing so will automatically move your question to the top of the forum list.
Web Site Host & Forums Monitor
Thank you; we did call our plumbing service this a..m. as not capable of removing pipes ourselves.....also discovered the unit is 5 yrs old, but I think you are right, somehow it got clogged.
Let me guess.....Two plungers, a pair of vise grips and $40.00 and the guy was out the door in ten minutes!
Let me know if the problem is still there, or the plumber didn't show up...maybe a easy fix, without having to take anything apart.
We have a contract with a service company that covers all appliances and air con; there were here, unscrewed the pipe, dumped the "clog", all is working well now,
BTW, plumbers here are $60/hr; electricians $72/hr.
thanks for your help..
Good to hear the clog has been taken care of and the bill was paid.
I really don't know how much a plumber would cost here. I usually will repair what I can. If I can't repair it, by the time I'm done with it, it has to be replaced!!
