Old Moen shower valve - need help!
I have a Moen shower valve that will not shut off. It was probably installed in the mid 1960s. I tried fixing it myself without success. Here are links to four photos I took of it since there is no model number anywhere.
http://members.cox.net/~yo-ro/images/moen1.jpg
http://members.cox.net/~yo-ro/images/moen2.jpg
http://members.cox.net/~yo-ro/images/moen3.jpg
http://members.cox.net/~yo-ro/images/moen3b.jpg
Any advice I receive will be greatly appreciated!
Thanks.
Robert
Thanks.
Robert
Moen shower valve
Sorry but I accidentally gave the wrong link for the fourth photo of the Moen shower valve. It should have been:
http://members.cox.net/~yo-ro/images/moen3a.jpg (not 3b).
Good pictures sir! I wish everyone did that.
Shut the water off at the main, not unless those are visible stops that protrude the wall below, then shut those off.
Then, pull that chrome piece off the valve. There will be a C clip that will fit in a slot that holds the cartridge in. Pull this clip out.
I can actually see the clip in your pictures.
Here is where it might get difficult. If you don't have a cartridge puller (most don't) then take a pliers or screw the handle back to the stem. Use this to pull the cartridge.
Some of these are a bear, and are extremely difficult to remove. The cartridge puller is your best bet.
Your cartridge I believe is a 1225, or 1220, one of those two I believe. Not one of my favorite brands. If you call Moen, www.moen.com, they will replace the parts free of charge. You have to call them.
http://www.moen.com/hidden/pdf/instr...id=40939a9a91d
Pull #8, then #4, then #7 and that will be the mode to remove your cartridge.
