Plumbers' wrench
Old 08-23-04, 07:35 AM
howy
Plumbers' wrench
Trying to locate a wrench or a special type of pliers which would allow me to tighten or undo a nut at the top of a pipe where there is not too much space. I can picture an offset socket wrench on a vertical post which has a cutout to allow for the pipe or a pair of pliers similar to that. What's the wrench called?
Thanks in advance for any help...
Old 08-23-04, 08:10 AM
You are describing a basin wrench, but how large of a nut are you trying to remove?
Old 08-23-04, 08:24 AM
howy
Not too much more than 1/2"
Old 08-23-04, 10:44 AM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
A basin wrench should do it.
Mike
Old 08-24-04, 09:04 AM
LazyPup
a basin wrench should do it fine,,if not, use a clawfoot wrench on a socket extension bar.
