Leaking Shower Stall
My shower is leaking into my neighbor's ceiling. I had the shower stall and drain resealed but it still continues to leak. What would be the next step in fixing this problem?
Thanks.
Thanks.
If the drain and shower stall have been "correctly " sealed then the next step is to check the drain line from the shower. Could be cracked or a bad connection. Good luck.
