What is a "thermostatic" shower?
Old 10-12-04, 06:45 PM
kuriouskat
Talking What is a "thermostatic" shower?
I'm in the process of having a house built and came across a "thermostatic" shower. When I googled the term - a lot of european web site's popped up. But they didn't really explain the "thermostatic" part of it.
Any and all advice appreciated.
Thanks!
Old 10-12-04, 07:12 PM
majakdragon's Avatar
Received 1 Upvote on 1 Post
From what I have seen, they maintain the water temperature even if another fixture is turned on. Sounds like a great concept....EXCEPT...the price is NOT nice. Good luck.
Old 10-12-04, 07:49 PM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
Would not a pressure balance valve be shorthand for thermostatic?
Old 10-12-04, 08:01 PM
Post
http://www.deltafaucet.com/aboutdelta/scald_guard.html
Balancing spool senses pressure imbalance and controls the rapid change of pressures in mixing valve.
These valves are code to protect from scalding and protect the disabled (people suffering from epileptic seizures) from extreme temperature change.
Old 10-14-04, 07:15 PM
kuriouskat
It is still pretty confusing to me. I came across this term in regards to a shower panel with massage jets, etc. I'm not sure if it refers to multiple functions ranging from regulated water temp -to- water pressure flow under the same umbrella.
Thanks for your insight.
Old 10-14-04, 07:30 PM
As Dunbar Plumber wrote, it controls the pressure and temperature at the same time. Ever been taking a shower and someone flushes a toilet? Stops that from happening. Became a safety issue a while back and most states made this type valve code.
