Tub Drain Problem
Tub Drain Problem
I was taking out the strainer from the drain to change it and the pipe that it screws into broke. Do I need to take out the tub? I can't get under the tub any other way. I would like to keep the tub if possible.
Received 1 Upvote
1 Post
If you can't get to it from behind the faucet wall, perhaps it's over a basement, crawlspace or ceiling?
Usually, one of those four is far easier than removing and re-installing a tub unit.
Mike
Mike
