Leaking tub faucet
Old 10-30-04, 07:06 AM
OneAfterAnother
Leaking tub faucet
I've had problem after problem in my upstairs bathroom of my newly purchased home. I have a shower/tub combo, three knobs. The hot water knob is causing the problem. When I turn it off, the water does not completely shut off. What is confusing me, is that I can turn it farther and it will come on a little more. There seems to be no stopping the knob from turning off. Up until a few days ago the knob would stop and the water would completely shut off. Any advice will be greatly appreciated. Thanks!
Old 10-30-04, 07:23 AM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
It may just be a bad washer on the end of the valve stem, or a worn valve.
Turn off the water, remove the handle and the retaining cap, and remove the valve.
Take it to a store and replace the washer on the end, and the o-ring if it has one. If it looks badly worn, you may just want to get a new valve.
Good luck!
Mike
Old 10-30-04, 07:26 AM
majakdragon's Avatar
Sounds like a worn out washer. Shut off the water supply and remove the cap on the hot water handle. (should have a pop-off cap,screwdriver works well).Take out the screw you will see and pull the handle off. Remove the cover plate and you should see a nut. Remove it by turning counterclockwise.Place the handle back on and unscrew the stem. Look at the end and you should see a washer with a screw holding it on. Remove the screw and take the washer off and purchase a new one. Reinstall by reversing procedure.
Welcome to the DIY forums and good luck with your project. Post back for more info or help by hitting the reply button to bring your post back to the top.
Old 10-30-04, 07:28 AM
Once again Mike and I agree.Got to quit meeting like this Mike. LOL
Old 10-30-04, 07:32 AM
OneAfterAnother
Wow! I can't believe I got two replies on this in a matter of minutes. Thanks for the advice. It sounds pretty simple, but I am a simple man. I will do the best I can. Rest assure if there are any problems, I will let you know. Thanks again for the timely help!!!
