changing closet flange orientation
I need to change the orientation of my toilet 90 degrees. Do I need to adjust the toilet/closet flange 90 degrees to properly align with the through bolts that will hold the toilet, or is there an easier alternative ( a kit of some sort?)? I have removed the screws attaching the flange to the floor but I can't see how to get the flange loose from the soil line to adjust it. Any help would be appreciated!!
Is the top of this flange flush to finish floor or below the finish floor or just above the finish floor?
This answer will tell me if you will be able to use a closet extension ring or not.
Hi MikeH,
Welcome to the DIY Forums.
You should be able to use a closet flange extender. Just change the orentation by turning the flange to where the closet bolt holes are 90 degrees from where they are now. The 4 screw down holes in the flange extender should match the holes in the old one.
Good luck on your project, post back with any questions on this or any other projects.
Well, that was my original plan exactly, but I guess what I am missing is how is the flange is attached to the soil/drain line. I haven't been able to 'persuade' it to loosen at all, and I am reluctant to really hammer on it...How do they attach? Just plumbers putty? Solder? Superglue?
Put silicone between the existing and the extension ring, screw it down and let dry for a couple of days, if you don't give it a seal it could leak into the floor. You might need to use 2 rings, the top of the flange needs to be 1/4" above the finish floor.
