Shower water woes
I have a Delta Monitor 1700 series single handle shower faucet (no tub) with an attached anti-scald hot/cold adjustment knob. The unit is about 3 years old and has been working fine until recently. Water pressure has dropped and the hot water will suddenly go cold and then back to hot. It is now to the point that a 5 minute hot shower is all you get before it gets cold again. If you play with the adjustment knob, it will eventually get back to hot. I have tested the bathroom sink hot water and water pressure throughout the house with everything else in working order.
Do I need to replace this unit or is there something that can be replaced from within?????
You will probably want to replace the cartridge in the valve click below for parts breakdown.
Delta Faucet 1700 series
Delta Web Site Link
If the link does not work, you will have to copy and paste it.
Post back if you need more help,
Thanks problem is fixed!!!
Turns out, there was a rock lodged right up against the inner shower-head oring which caused the water pressure problem. I was also able to clear the cartridge during this time. Thanks again......
