Toilet sweat
Old 12-10-04, 10:43 AM
tarahill
Toilet sweat
hi my father lives in virgina and his toilet is always sweating,,,what would cause this,,,thank you
Old 12-10-04, 11:15 AM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
Humidity in the room, if there no ceiling fan in the bathroom to help keep the humidity down?
Old 12-10-04, 11:18 AM
tarahill
hi
thank you very much,,,,,,he probly has the heat too high,,,,,thanks
Old 12-10-04, 11:42 AM
tarahill
hi
is there any way to solve this,,,with out putting in a fan???? thanks
Old 12-10-04, 06:04 PM
Well you need to be able to remove the moisture in the air out of the room, is the tank the only part of the toilet that sweats or is the sweat happening to both the tank and toilet bowl?
Old 12-10-04, 06:12 PM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
Proper ventilation is the best solution to condensation ("sweat") caused by warm, moist air in the bathroom coming into contact with a toilet tank with cold water in it.
There also are foam insulation kits that you can get to go inside the tank.
In extreme situations, you can get a mixing valve (and run a hot water supply line over to it) to send warm water into the tank.
Improve the ventilation first.
Good luck!
Mike
Old 12-11-04, 07:59 AM
tarahill
hi
thanks to evrybody for the help and info...will try the better ventilate the bathroom ..bye
