pluged shower drain
Old 12-13-04, 01:03 PM
ironmanL21
pluged shower drain
the drain on my shower is pluged probably due to my wife washing my german sheperd in there. I tryed some chemical drain cleaner with no luck. so i went and got a small snake and im trying to go through the over flow . i can only get aprx. 2 ft of it in until i hit some thing that shure sounds like metal. any help would be greatly appreciated.
Old 12-13-04, 01:39 PM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
Your hitting the trap, there tricky to get around, keep trying.
Old 12-14-04, 10:24 AM
ironmanL21
had no luck getting the snake in but i stuffed a rag in the over flow to stop the air flow and worked on the drain with a plunger. it losened up enough to start draining again but still runs a little slow i think. since i cant get a snake in what other metheds can i us to clean the drain and pipes out?
Old 12-14-04, 02:31 PM
Try a drain cleaning product.
Old 12-14-04, 08:31 PM
Bend the very end of the cable slightly 2" back..........then try spinning the cable in reverse while pushing into the drain.
Also, try jabbing it in with a soft touch while the cable is not in motion.
Have to romance drains like what you have; if water passes through it, most times a small cable will also.
