Fluidmaster fill valve problem
Received 0 Votes
Toilet working great till to day ,it was flushed but it didn't fill back up.Took the valve apart and cleaned it run water into tank with valve out,worked ok.Put valve back in and the tank filled,flushed it and it didn't fill again.I did this several times and it always did the same thing again.Whats up?Cecil.
Received 0 Votes
Most of the time you can fix these just by removing the top cap. With the cap off,hold a rag over the top and turn on the water a little. You should get good flow of here, and also flush out any possible debris. Now just install a new seal washer in the cap and put it back on.
