Kid flushed something down toilet, what do I do?
If the bottle made it past the toilets internal trap it will probably not cause a problem. You won't notice a problem until paper is flushed as the water will find a way around it. If it starts backing up you can try a Closet auger or remove the toilet and clear it from the bottom. Closet augers can be rented and would probably break up the plastic bottle. Good luck.
