Leaky Shower Head
Old 01-01-05, 08:59 AM
jet3767
Question Leaky Shower Head
Hello, when we left home for the holidays we decided to leave our faucets dripping because of severe cold weather to keep our pipes from freezing. When we returned home we discovered that our shower will not shut off as it had before, instead it continuously has the slow stream as we had left it. How do I get this to stop????? I removed the shower head but don't believe it was the problem because it continued to run. The faucet has the one dial that turns in a circular motion to adjust the temperature.
Thanks in advance!!!
Old 01-01-05, 09:41 AM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
Install a new cartridge in the valve, should solve this problem.
Old 01-02-05, 05:16 AM
jet3767
Thanks for your help! I will try it out.
Old 01-15-05, 06:26 AM
jet3767
Product Number???
This is a Moen shower faucet, and I can't seem to find the product number anywhere on the faucet. Is there a place where the product number is stamped? The metal plate behind the handle has 'tanadyn' stamped on it. I would like to know this so I can purchase the correct cartridge and so that I can get the product info from the company website to see how to install the cartridge. Thanks.
Old 01-15-05, 06:33 AM
majakdragon's Avatar
Received 1 Upvote on 1 Post
jet3767, Welcome to the DIY Forums.
Moen has lifetime guarantees on a lot of there faucets. I am including their wesite and toll free number. Good luck.
Moen 1-800-BUY-MOEN (289-6636)
http://www.moen.com/
Old 01-15-05, 08:38 AM
jet3767
Dragon, Thanks but I tried that. They said it doesn't apply if you are not the original owner.
Old 01-21-05, 10:47 AM
jet3767
Thanks!!!
Got it done guys, Thanks! Found the right part after talking to someone at Moen, then found the diagram to replace the part. Took 10 minutes and that included the trips to the basement to turn on/off the water.
