Moen Single Handle Tub/Shower Faucet
Does anyone know if it's possible to remove a Moen "Dialcet" single handle tub/shower faucet without the special cartridge tool?
I've got the plastic handle off but I can't get my needlenose pliers or screwdriver in there to remove the clip and I don't want to damage it because I'm not replacing it (hopefully), just repairing a leak behind it.
If I need a Moen cartridge remover tool, is there a special one just for tub/shower faucets or is it the same one as used in sink faucet removal?
Thanks
A.
Thanks
A.
Hi Lazykinz.
-There are so many Moen units it's hard to remember names. ALL Moen shower units go by a long #, embossed INSIDE the handle. Your clip is easy to remove, you just need longer, thinner pliers, or a strong tweezer. most big hardware/plumbing stores ( including HD ) have a Moen Repair Kit. Take your broken/worn piece and you will get a replacement free. If you can't find a store with the kit, try local plumbing wholesaler.
Do it Right - Do it once.
Free?
Hi Nomind,what do u mean free?Do they give a lifetime warranty?I just went thru an ordeal with a 1222 positemp,had to order kits from moen at $12.00 a pop.You can remove em,at home depot the replacement cartridge is 36.00 and comes with a plastic tool that you slide down the shaft and turn 45 degrees with a slip joint plier.I had sediment issues so I ordered the rebuilds instead of the 36 a pop,but if they are free I want a refund lol
Good Luck
Good Luck
Below is the Moen Website. Click on it and go to Product Info and the Lifetime Warranty is explained. Good luck.
http://www.moen.com/
