Kitchen faucet cam seal problem
I have an older Peerless ball type, single handle kitchen faucet. I replaced the cam/seal to stop it from dribbling water under the cap assembly. I had to tighten the adjuster ring so much to stop it from leaking under the cap when I turn the faucet on that I could hardly move the handle at all. The Danco cam/seal was made for Delta/Peerless and looks the same as the old one. I ended up putting the old seal back in just so I can use it. What gives?
O Rings
I replaced the O rings under the spout, cleaned the ball, and reassembled it with the new cam/seal. It still requires excessive force to move the handle if I adjust it to not leak when the faucet is turned on. The new cam/seal is supposed to make it easy, not hard to use, so what might the problem be?
Did you use FDA approved food grease to lube all moving parts?
Looks like clear silicone that never gels/hardens up that is an approved lubricant for faucets, valves, moving parts in plumbing that comes in contact with potable water.
This will fix your problem; in that camber assembly there is a plastic adjustable collar that can be turned counter-clockwise that holds that assembly. Tighten till you reach a comfortable setting to move the handle.
I stay away from all Danco faucet repair parts; OEM is your best bet.
