bathtub leaking
Old 02-13-05, 07:17 AM
tbruce
bathtub leaking
Hi I'm having a little trouble with my bath tub. When someone gets a bath and fills it to the over flow point it seems that the tub leaks (or i guess it's the overflow. I took off the overflow cover just to look at it and I just wanted to know if there is supposed to be a visible seal there anywhere? Or is there anything that I can check for here? Thanks for any help with this.
Old 02-13-05, 07:21 AM
majakdragon's Avatar
There should be a rubber gasket that fits on the backside of the overflow plate (on the outside of the tub) and is held in place with the screws that hold the plate. It may be split or it may have fell down. Good luck.
Old 02-13-05, 11:23 AM
tbruce
thanks I'l have a look at that, thanks again for your help
