Installing new Delta tub/shower valve
I am installing a new single handle Delta tub/shower valve. I have ripped all the sheetrock off the wall and have removed the old valve assembly.
My question is the Delta valve body comes with a "Plaster Guard" - a plastic ring screwed to the valve body. However, the instructions are real confusing as to how to place this valve.
I will be using 1/2 green board, with 3/8 cultured marble panel attached as my finish surface. Do I install the valve body with the plastic plaster guard flush with the sheet rock, or out 3/8 to be flush with the marble?
I have called Delta help line . . . spoke with three different people . . . and go three different answers.
Any help would be appreciated.
Hi doitright,
-that Delta system has to be flush with the outermost surface. ie the marble front in your case.
Do it Right - do it once.
