Are All Single Handle Tub/Shower Faucets Interchangeable ???
I currently have a single handle Delta Faucet. It is the lever type which you raise it to the left (9 O'clock) it is all hot and raise it to the right (3 O'clock) for all cold and straight down (6 O'clock) for off.
My kids have a really hard time setting the right temperature when they are in the tub and sometimes so do I when I am in the shower.
I want to replace it with the single handle dial type, you know the kind that you turn it all the way for full hot.
Can I purchase this type of faucet with my current set up or are these two systems totally different and not compatible?
Thanks in advance for any help!
Different manufacturers do things different so it is unlikely that any other names are intercahangable. You may want to check with Delta to see if they make what you want. Good luck.
Delta 1-800-345-DELTA (3358)
http://www.deltafaucet.com/
