toilet flange
Old 05-12-05, 08:28 AM
parfour
toilet flange
I recently put ceramic tile in my bathroom and the tile is now flush/level with the toilet flange. Does the toilet flange need to be elevated above the tile, if so how much? or can it be level with the floor tile? I have a standard cheapest cost toilet in the bathroom?
Old 05-12-05, 09:03 AM
majakdragon's Avatar
Received 1 Upvote on 1 Post
The flange can be flush with the floor. Good luck with your project.
Old 05-12-05, 09:10 AM
parfour
I knew that I should have asked first. Well, the flange is on the second floor so I unscrewed the flange screws and lifted the flange up about 1/2 inch and put 1/2 sockets (tool wratchet sockets) around and under the flange. Then I poured liquidfied mortar under and around the flange and tightened down the flange. It seems pretty tight, level and is about 1/2 inch above tile. Is this okay??
Old 05-12-05, 09:36 AM
You are still okay as long as the flange cannot rock, which could break it off. There is a difference of opinion on which method is better, above or level with floor. I personally do not like a lot of space that has to be filled in by the wax seal to prevent leaks.
Old 05-12-05, 01:22 PM
parfour
will there be more or less space for the wax ring to fill in by being flush with the tile or above the tile? I could put it back flush if needed.
Old 05-12-05, 11:47 PM
There will be more space to fill in. Buy a thicker wax seal. They usually sell a thick and a standard one. You should have no problems. Don't panic.
