Leak from base of KWC "Domo" Kitchen Faucet
Old 05-20-05, 02:51 PM
garbid
Water is slowly leaking from the base of my KWC "Domo" single-lever pull-out kitchen faucet (Model K.10.61.33)- at the point where the base meets the sinktop. Any ideas as to what might be causing the leak? These things are very expensive to replace and I'd rather defer doing that for a few more years. Thanks for your help.
Garbid
Old 05-21-05, 07:58 AM
I am not aware of that brand name but knowing from the numerous faucets I rebuild that the upper and lower O-rings on the spout have something to do with this.
I would contact the manufacturer and ask for a full rebuild kit for all the wearable parts inside the faucet. Make sure you use plumber's grease on all moving parts and fine threads.
