Bathtub Drain
Bathtub Drain
How do i get the tub drain to unscrew from the tub. All there is is the round metal drain piece that i guess screws onto the tub drain. Cannot get this loose to unscrew from tub.
Thanks.....Alex
Thanks.....Alex
Received 0 Votes
You can always try using a couple of screwdrivers to unscrew it. However, your local home improvement store should have a special tool in the plumbing section that has a couple of prongs sticking out one (or both) of the ends that allow you to unscrew the tub drain. It is called something like, "ub drain removal tool".
Shawn
Shawn
Received 0 Votes
Typically, when the drain cover is removed (which is held in place by a single screw), at the bottom of the drain basket is a piece of metal bisecting the drain basket. This piece is the receiving end for the screw. If you do not have this the only other way I can think of is to use a recripocating saw and careful cut through the drain basket so that you can bend it and remove it. However, I am not a plumber so there may be a better solution.
I would not use a recripocating saw in the bathtub,I would however make a couple of notches in the edge of the drain basket. These can be made with a chisel to help turn the basket. Make sure you tap the basket in a counter-clockwise direction. This should loosen up the basket and allow it to unscrew.
Good luck with your project.
