Which wax ring for offset toilet flange??
Old 07-31-05, 12:07 PM
grillstir
Which wax ring is better for an offset toilet flange: the one with the plastic sleeve or the one without the plastic sleeve? or does it matter?
Thanks
Old 07-31-05, 06:15 PM
majakdragon's Avatar
Received 1 Upvote on 1 Post
grillstir, Welcome to the DIY Forums.
Iwould use the one without the funnel. Some places they are not code (even though you can buy them). The other reason is the offset flange. These already partially block the drain. No use adding to the problem. Good luck.
