leak free solution?
leak free solution?
Hi,
I have recently tiled my bathroom and want to confirm the advice I was given. I was told not to worry about the heigth for the flange as it was set in concrete in a basement. The tile thickness is approximately 3/8" higher than the flange and I was sold some reusable flange gaskets of different thicknesses. He said just install the gaskets that bring you above the new floor height and leave a bit of gasket above for a seal on the horn. He made no mention of a plummers putty or any type of caulk product around the toilet. Is this the correct way or is there a better way to seal this toilet? Thank you in advance!
These "gaskets", are they plastic? If so, they are called flange extenders. They should have a seal substance on one side to seal it to the original flange. These also have to be attached to the floor through the holes provided (4) in the original flange and the extender.
The choice of caulk or putty is yours. It isn't needed and will have nothing to do with the toilet leaking. The wax seal you install will do that. If you decide to caulk, grout, or putty the base of the bowl, I would suggest leaving the back side of the bowl open. This way, if you do have a leak, it will show up faster instead of seeping into or under the tile until it starts loosening them and you have a major repair job to do. Good luck.
Hi Majakdragon, and thank you for the reply. The gaskets in question seem to be made of an almost rubber-foam like consitiency. No plastic or wax like a traditional seal. I guess that is why I was questioning them. I have used the typical wax "jonny ring" in the past but never these reusable ones. Is there a better product to use to achieve leak free results in my application? I am open to suggestions. Thanks!
By the way: I love the "crunchy & tatses good with ketchup"
I have not seen what they gave you but I would get a flange extender (or 2) to make up the difference in height between the existing flange and the tile. Being an "old time " plumber, I stick with what has worked for years. I have read in these Forums about a new seal that is reusable. What I read were complaints. I would use the wax seal and make sure to sit the bowl straight down onto it. This is about as close to leak free as can be obtained. Good luck.
Glad you like my signiture. Used to read:" If you have never made a mistake, you haven't done much."
Toilet flange
Originally Posted by jaws
Hi,
Originally Posted by shacko
What you were told is wrong, the flange should be on the top of the tile, but you can work with what you have.
Originally Posted by shako
Use what is called a Kant-leak or if you can't find them use two wax seals..
Putty has been banned in this situation for many years.
Caulking is your call, on a lower floor you can get away with it not going all around the bowl; on a upper floor don't do this! Luck.
In my above answers I was assuming you were speaking of the caulking around the OUTSIDE of the base of the toilet. Leaving the back open would give you notice that you have a leak BEFORE it soaks under the tile you just installed.
Hi Majakdragon,
And thank you again, yes I was making reference to a caulk around the base of the toilet. I have heard of people using plummers putty also around the base. I do understand the flange needs to be sealed with a wax ring and not a caulk type product. I went to the local hardware store over the weekend and believe I have the "right" solution for the job. I appreciate all the help and advice. Thanks again
