kohler faucet handle loose
The knob for cold water on our recently installed (self) kohler faucet and pedestal sink is loose.
Does not leak and water turns on/off properly; its just that the handle is loose.
The hot and cold knobs are about 8" apart and sit in their own holes in the pedestal sink.
Thoughts on how to tighten?
Look up the model number or match up the design of faucet on Kohler.com and open up the PDF files to see the parts explosion of your exact faucet.
From there you will be able to see the assembly of the faucet and determine what needs to be tightened in order to correct the problem you are having.
