Help!!! Back up durning remodel
With the toilet off, the plywood floor exposed and the flange stuffed with a rag, the pipe backed up after the upstairs toilet was flushed and the dishwasher was running. Just a coincidence? We've been using the upstairs bathroom for a week now, with the downstairs toilet off and nothing has happened.
Thoughts?
Thanks...
Kevin
Thoughts?
Thanks...
Kevin
Thank you for your reply. That's all it was. Actually fixed itself. I put the new toilet on and went to go borrow a snake and it all unclogged itself.
BUT... now I have a new problem. Trying to tighten the nuts on the toilet bolts, one of the bolts keeps sliding over and popping up and off of the flange. Twice it's happened.
How do I keep that bolt in place?
Kevin
Kevin
I thought I had it in there solidly, since what happened the first time I didn't want to happen again. But it did. I don't know if it is because there is a slight angle in the porcelain, so as I tighten the nut, the bolt starts sliding with the downward slope of the porcelain?
Bummer, it's happened twice. What if I put a screw next to the bolt to keep it from happening again? Your thoughts on that?
Thank you for all your help, I appreciate it. It sucks being on this end 'cause I know what's happening and can imagine what people are thinking and that I must be borderline insane, thinking, "No, it shouldn't being doing that"
kw
kw
