Toilet
Old 09-18-05, 05:45 AM
mnzace
Toilet
k i am not sure what the problem is with my toilet and how to fix it all i do know is that it keeps backing up. what can i use to see if anything is in there and if there is what can i use to get it out i used a snke that we purchased from our local home depot but that didnt work so we returned it
Old 09-18-05, 06:54 PM
majakdragon's Avatar
If the clog is in the toilet itself, you can use a closet auger. These can be rented or bought. You may have a clog in the main drain under the toilet. For this, you will have to remove the toilet and use a heavy duty snake or auger. Good luck.
