Removing tub help?
Removing tub help?
I'm removing the tub to put down new sub flooring in intire bathroom. House is peer and beem. When I take the drain out of the tub is that all the disconnecting there is or do I need to get under the house at the tub and take something elese loose ? I have the knobes and inside things already off.
Thanks
jim123
Thanks
jim123
Glad it worked.. I'm going to assume you're reinstalling the same tub after floor repairs. If so - remember, if your floor height changes, you'll have to change the length of the drain pipes (should be adjustable fittings before the p-trap). Having an access panel would make that job a lot easier....
Yes i'm going back with the same tub and replacing the 3/4 what I call partical board (the stuff that swells up twice its size when it gets wet) with 3/4 plywood. Dont have a access panel as you mention but thats a good idea. May try to figure out where to put one. Any sugestions?
Thanks
Jim123
Thanks
Jim123
