Adjusting water level on toilet without ball & lever?
Have a Mansfield toilet and I need to adjust the water level (if you can) it is about 3/4" low. Problem is I do not know how to do it as it does not have the typical ball & lever, instead it has a straight tube looking thing that says "Korky" & "anti-siphon" on it and this connects via a hose to the filler tube. Am I able to adjust this thing(easily?) thanks!
kepico, Welcome to the DIY Forums.
Turn off the water supply under the toilet tank. Turn the upper half of valve counter-clockwise to unlock. Pull up until the line on the valve is equal with the water level line on the inside of the tank. Then turn clockwise until the valve snaps into the locked position. Turn water supply back on. These are the instructions from the Korky website. Good luck.
