Clogged bath tub - Need suggestion
Hi,
The shower tub in one of our bathroom is clogged. I once used drano and it seems to remove the clog but, after a month or so, it gets clogged again. I don't want to use drano because, I read somewhere (maybe in this forum) that its corrosive to the pipes.
Is there an alternative to drano?. Does someone provide service to clean clogged drainage pipes (and guarantee it)?. Or, is my only option is to remove the tub and clear up the clog?.
Any help/suggestions is appreciated.
Thanks,
Ansari
Thanks,
Ansari
Get some of this stuff in the Depot. Zep makes good products and it says it is non corrosive.
http://www.zepcommercial.com/pages/h...airclogsAnchor
The usual clog in a shower is hair. Best treated by digging out the clog with a coat hanger. Ugly, but effective.
Do not use a coat hanger
. if your trap is weakened by the previous draino or just normal wear and tear you could put a hole in it. Most bathtub drains are heavy brass,but don't take the chance yours isn't.
I don't think a coat hanger is ever a wise decision----ever
You can get a cheap snake in the Depot that will not puncture the trap, and you don't need a drill to operate it. it has an s type handle that you can turn.. If you use it go in from the over flow plate at the top of the tub. It is straight down to the trap. It may be a good idea to invest in one under the circumstances.
joneq:
Appreciate the tip - we've always used the coat hanger in our rental units, but not anymore.
I have done this in the past, and unclogged the tub using this method:
First, I place a towel in the overflow to prevent air from getting in.
Next I fill the tub with cold water at about 2 inches. I then use a plunger at the drain until all the water drains normally.
I repeat if I need too.
