His-Her bathroom sinks
Old 11-08-05, 08:37 AM
Pocket
Assuming that water pressure will be impacted some (when used at the same time), can dual bathroom sinks (his-her sinks) be split off the same water pipes?
I am re-doing our bathroom and dual sinks is the plan.
Thanks.
Old 11-08-05, 11:03 AM
Yes - you may experience minor pressure differences... but not bad...
Old 11-08-05, 08:03 PM
majakdragon's Avatar
You will be tying into 1/2" lines for the water supply. The supply tubes going to the sinks are 3/8". You should have no problems. Good luck.
Old 11-08-05, 08:06 PM
Pocket
thanks
Thanks for the tips!
I figured this wouldn't be an issue, but I wanted to double-check.
